lverberkt
Nov 05, 2019Aspirant
WiFi problems with Netgear nighthawk R7800
Hello, I'm having issues with my wireless connections, 2.4 and 5 ghz. The WiFi is enabled according to the second light of the right is on. When I login with routerlogin.net I see wireless warning off...
Netduma_Alex
Nov 06, 2019NetDuma Partner
Under Wireless Settings, have you hidden the SSID? Are you using Smart Connect?
lverberkt
Nov 06, 2019Aspirant
Hello,
network is not hidden and smart remote is enabled.
