brew_me
Feb 09, 2021Aspirant
WiFi resetting daily
Hello, I have the latest XR1000 gaming router (option wasn't availble to select). Almost everyday or every other day, I need to reset my router. All the lights are on the router as if I'm getti...
brew_me
Feb 18, 2021Aspirant
Smart Connect is disabled. All of my devices are on 2.4G except for my gaming pc which is on 5G. All wireless connections do not work, but the LAN connection does.
Netduma-Liam
Feb 19, 2021NetDuma Partner
Do you have Armor enabled? If so could you please disable it?
What firmware version are you currently running?
