kopyone's avatar
kopyone
WiFi won’t turn on after downgrading firmware XR500
Hello,
I updated to the beta firmware 2.3.2.108 recently. I had some issues, so downgraded back to 2.3.2.66 and now my Wifi will not turn on and i always get the message "DumaOS not loaded yet"
I tried resetting to factory with the reset button on the back, i tried the 30-30-30 reset. i have flashed other previous firmwares, by TFTP, i can not get the wifi to come back on, and always get the "DumaOS not loaded yet" message when trying to log in to the interface.
If i do a factory reset, it loads the initial setup screens and i can set the admin password, wifi SSID and password, etc.... but after that, nothing. and the Wifi never turns on.
Any idea what could have happened or how to fix it? I have searched for the issue, and none of the fixes i've found work...
Ironically, as a last resort, I TFTP'd the latest supported DD-WRT build, and everything works great... wifi and all. But as soon as i try to upload and of the official firmwares, the same thing happens. I'm at a loss of what to do now.
Thanks for any help I can get!
  • Clear the browser cache/cookies as it may be trying to load the beta versions of the pages still, assuming you then have access, disable WiFi from Settings > Advanced > Advanced Wireless settings then reboot, enable it again and reboot and see if that works.
  • Actually now nothing happens as all. Only the usb2 light comes on and nothing else.
    No reset will work. Tftp will not connect. I even disassembled the router and tried connecting to the serial header..... nothing.
    It’s basically a paperweight.
    I think it’s toast.
    • Netduma-Liam's avatar
      Netduma-Liam
      NetDuma Partner
      OK,
      Are you also no longer able to access the interface via your browser?
      Are there no lights at all on the unit or are any lights showing orange?
      • kopyone's avatar
        kopyone
        Correct. No lights whatsoever except the USB2 light is on. Nothing changes that.
        Tried 30-30-30 reset, tried connecting to tftp, even tried disassembling the unit and connecting to serial pins with putty.
        Nothing whatsoever.
