busolof's avatar
Mar 25, 2020
will airvpn working with netgear xr500!!
Hey, thinking to buy Netgear XR500 and using today airvpn my vpn provider is that working with that router. have an config file from airvpn opvn.   Kind Regards   Bnegt
  • Netduma-Fraser's avatar
    Mar 25, 2020
    We haven't specifically tested that VPN provider but as you have the OpenVPN config file from them then there is no reason it shouldn't work with the router HybridVPN feature using the Advanced configuration.
