Misterswede
Jan 29, 2022Guide
Will not accept support is closed on XR700
Netgear this is very bad 2 years WHAT The hmmmmmmm After a auto update and shutdown DUMA OS will not start I have tried Reset, factory reset, TFTP upload of new firmware and even downgrade too o...
Misterswede
Jan 31, 2022Guide
All is Done I have also tried 3 firmware installs via TFTP
I can. It get duma os to work
I found an secret advanced html page for duma os that works but it’s not complete
So DumaOs is dead in normal mode.
michaelkenward
Jan 31, 2022Guru - Experienced User
What does the power LED look like on your router?
I ask because you mention using TFTP. This is a trick operation that can go wrong.
TFTP is needed only if you have corrupt firmware. The way to check for that is if the power LED is not normal.
If that LED is flashing, the firmware is probably bust. If it is normal, solid white, using TFTP can cause damage.
If the LED is solid white, then you can use the normal manual firmware update.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- MisterswedeJan 31, 2022GuideTFTP function says send ok and the system does everything correct in the installation process
I also try downgrade and in the dumaos advanced html it says correct as old firmware. I the upgrade the firmware and back again to duma is in not loaded yet
The power led ok. Wi-Fi ok and wps led ok
No 2.4 or 5ghz led is lit
SSid not found in iPhone or other Wi-Fi device
But is enabled in advanced duma html- Netduma-LiamJan 31, 2022NetDuma Partner
Please confirm exactly which firmware version you last upgraded to.
After factory resetting, were you met with the setup wizard? If not, you likely did not factory reset the XR properly OR the error message is cached in your browser and you need to clear your cache. That error message only occurs after setup has been complete.
- MisterswedeJan 31, 2022GuideYes strange after 5 times with 30-30-30
It still remember my password for login
Once Of the 5 times I got the guide for new setup but when done and duma should start I says duma os not started yet
