Thomo1318
Jun 09, 2019Aspirant
Will there be a new one soon?
I am currently about to upgrade my router... But with wifi 6/ax on the horizon I don’t know if the upgrade the the XR700 is worth the upgrade since it will soon be old tech. Hence looking at a switc...
Jun 09, 2019Guru - Experienced User
there's also the RAX200 to consider. It was supposed to be released in early July but has been pushed back.
https://www.netgear.com/home/products/networking/wifi-routers/RAX200.aspx
- Thomo1318Jun 09, 2019AspirantRAX200 = AX12
- plemansJun 09, 2019Guru - Experienced User
Thomo1318 wrote:
RAX200 = AX12AX12=RAX120 not rax200.
https://www.netgear.com/home/products/networking/wifi-routers/RAX120.aspx
- Thomo1318Jun 09, 2019AspirantI stand corrected...
Looking at the tech specs, apart from the upgrade to wifi 6 the other tech specs still don’t marry up to the RX700
The RAX200 is AX11000 not ax12. Similar devices but with some differences.
