Thomo1318
Jun 09, 2019Aspirant
Will there be a new one soon?
I am currently about to upgrade my router... But with wifi 6/ax on the horizon I don’t know if the upgrade the the XR700 is worth the upgrade since it will soon be old tech. Hence looking at a switc...
Thomo1318
RAX200 = AX12
Jun 09, 2019Guru - Experienced User
Thomo1318 wrote:
RAX200 = AX12
AX12=RAX120 not rax200.
https://www.netgear.com/home/products/networking/wifi-routers/RAX120.aspx
- Thomo1318Jun 09, 2019AspirantI stand corrected...
Looking at the tech specs, apart from the upgrade to wifi 6 the other tech specs still don’t marry up to the RX700- plemansJun 09, 2019Guru - Experienced User
Looking at the tech specs, apart from the upgrade to wifi 6 the other tech specs still don’t marry up to the RX700Depends on your usage. Yes the XR700 has 10g port but I don't know of a consumer modem that supports this. The RAX200 supports link aggregation for wan port or using the 2.5g port for wan. More likely to see consumer modems with 2.5g or link aggregation.
Rax has triband so you can separate out devices. Its tough to compare processors as their different suppliers (Annapurna vs broadcom).
Little bit of differences but I'd hold off until wifi 6 has been ratified if you can. I think it'll give time for the firmware to stabilize and truly see a comparison in speeds.
- Netduma-FraserJun 11, 2019NetDuma PartnerJust my two cents, there are currently no devices that I am aware of that support AX WiFi and so any of your current devices would not see the benefit of that technology even if you had a router that used it.
