Whirrlz
Jul 02, 2019Aspirant
Windows 10 - XBOX App Strict NAT - Nighthawk XR500
Got this new router today. XBOX App is telling me my NAT is strict. I have no idea how to fix this. People have said to do DMZ stuff and I don't know what that means even after looking it up. People ...
Jul 02, 2019Guru - Experienced User
Built in router here? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
Whirrlz
Firmware Version - V2.3.2.40
Manufacturer of Modem/Router combo is Arris BGW210-700
This Modem/Router (Arris BGW210-700) combo that AT&T gave us is not gamer friendly which is why I purchased this Nighthawk thinking it was a simple plug and play solution.
I turned off all radio broadcasts in the AT&T Modem/Router. This Modem/Router is confusing to mess with. I cannot find any DMZ setting anywhere. I don't even think the page has DMZ anywhere listed. I CTRL+F and never finds it. It does have IP Passthrough setting though. Don't know what that means though or what to do. Sorry
