Whirrlz
Jul 02, 2019Aspirant
Windows 10 - XBOX App Strict NAT - Nighthawk XR500
Got this new router today. XBOX App is telling me my NAT is strict. I have no idea how to fix this. People have said to do DMZ stuff and I don't know what that means even after looking it up. People ...
Jul 02, 2019Guru - Experienced User
Built in router here? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
Whirrlz
Okay. I turned Allocation mode on to Passthrough
Passthrough mode to DHCPS-fixed
Passthrough MAC address is the one that goes with XR500 Nighthawk. I clicked it. And pressed save.
It now says my NAT type is moderate.
- Netduma_AlexJul 03, 2019NetDuma Partner
Cool, that's progress.
Now you should go to DumaOS and go to Settings > Advanced Settings > Port Forwarding > Add Service and enter the ports (search Xbox Port Forarding to find right ports) and the IP address of your console (can be found in Device Manager or on the Xbox itself)
If this fails, you could put the Xbox into the DMZ by going to Settings > Setup > WAN Setup and putting the Xbox's IP into "default DMZ server" but this isn't an ideal long term solution as it's relatively insecure. Definately don't put a PC into the DMZ!
