TheMrYesac
Jun 06, 2020Follower
Wired Connection defaults to 2.4GHz
I have 3 PCs plugged in to my router via ethernet cables, but only one is connecting to the 5Ghz network. is there any way I can force the others to connect to this instead of 2.4GHz?
Jun 09, 2020Guru - Experienced User
If they're wired in, why are they connected to the wireless at all?
- Netduma-FraserJun 09, 2020NetDuma PartnerAs above, could you clarify please?
