Ozule
Oct 27, 2020Aspirant
Wired devices cannot connect with wireless devices
Hi, Hope someone can help me with this issue. Since I changed my ISP I cannot connect wired devices with wireless devices in my home network. I have tried everything, restoring the router, changi...
Oct 27, 2020Guru - Experienced User
that whole "the router from my isp works flawlessly" seems to indicate that you have it running on the network .
How exactly is your network setup with models/setup.
modem/gateway-------->router----->another router?/switches?
be specific in what you have setup and running. You could be in a double nat if you have 2 routers running on the same network.
https://kb.netgear.com/30186/What-is-Double-NAT
Ozule
Hi,
I have a ONT then an ethernet from it to the Netgear. I had to set up the VLAN with specific ISP values.
Router: Nighthawk XR500
No additiional routers
1 Switch in the living room.
Cheers
- plemansOct 27, 2020Guru - Experienced User
who's your isp and what ont are you using?
- OzuleOct 27, 2020Aspirant
My ISP is Orange (Spain). The ONET is Nokia G-010G-P
Also I didn't check the double NAT thing... I can see in the Device Manager field that most of my wireless devices have both IPV6 address and local IPV4 address... could this be the reason? Sorry if I'm saying something nosense, this goes far my knowledge. :)
Here you have an screenshot of what I can see in Devige Manager field.
- Netduma-FraserOct 27, 2020NetDuma PartnerIt's unlikely but disable IPv6 just in case. If you try to access devices that are connected via the same method e.g. eth2eth, 2.4to2.4, 5to5GHz does it work then?
