bacevedo
Oct 09, 2018NETGEAR Employee Retired
Wired vs Wireless: The answer may surprise you!
Wired vs Wireless.
The Debate.
This has been the debate of gamers since the beginning of wireless computing... and wired has traditionally won. Let’s take a couple minutes to exami...
theonlyway
Mar 25, 2019Aspirant
I have the XR700 and currently my wireless is faster than my ethernet. Its a bit disappointing considering the ac1900 was faster in both regards
- FURRYe38Mar 25, 2019Guru - Experienced User
What FIrmware version is currently loaded?
What are your results wireless vs wired?
What devices are you using to test wireless vs wired?
What speeds do you pay for from your ISP?
- Netduma-FraserMar 26, 2019NetDuma PartnerIn addition to the above questions what type of ethernet cables are you using?
