TheRealOC
Oct 25, 2020Aspirant
Wireless networks not functioning and can't access XR500 dashboard
Evening all, Having some trouble with my XR500 and would greatly appreciate any advice. Apologies for the long post, but I'm not a networking expert by any means, and I'm not sure what's relevan...
Netduma-Fraser
Oct 26, 2020NetDuma Partner
Thank you for the information. Regarding the interface, when you can't access it try using the LAN IP instead which by default is 192.168.1.1 and see if you can access then. Regarding WiFi, 'forget' the WiFi credentials on each device and then try to reconnect with the new details you made and see if they connect.
