LegionLord
Feb 07, 2019Follower
Wireless Networks will not enable
So yesterday all devices lost internet access. I checked and router has the most recent firmware. I check the boxes for "enable SSID broadcast" and apply. Even rebooted router. Can not see our wi...
Feb 07, 2019Guru - Experienced User
What FW is currently loaded?
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
Try a factory reset and set up the router from scratch.
LegionLord wrote:
So yesterday all devices lost internet access. I checked and router has the most recent firmware. I check the boxes for "enable SSID broadcast" and apply. Even rebooted router. Can not see our wireless network for devices to connect to. Any ideas?
- Netduma_JackFeb 07, 2019NetDuma Partner
If you connect an ethernet cable into a LAN port on the router and the other end into your PC, can you access the internet? Can you also access the router settings (at routerlogin.net)?
