LegionLord
Feb 07, 2019Follower
Wireless Networks will not enable
So yesterday all devices lost internet access. I checked and router has the most recent firmware. I check the boxes for "enable SSID broadcast" and apply. Even rebooted router. Can not see our wi...
Blazey
Feb 07, 2019Initiate
This happened to me on 2/5/19 on my XR500 router. This issue appears to be within update Firmware 2.3.2.40.
After various troubleshooting, the only thing that worked was reverting back to previous Firmware 2.3.2.22 and everything worked again as expected.
I didn't have Firmware update 2.3.2.32 saved so I did not test that at this time.
Netduma-Fraser
Feb 07, 2019NetDuma Partner
Thanks for the workaround Blazey, when did the issue present itself to you?
- BlazeyFeb 07, 2019Initiate
This happened to me on 2/5/19 at approximately 5pm EST. LAN/Wireless had worked in the afternoon on my home network, then stopped working between 4-6pm EST.
To be clear, the issue that affected me was with all devices at once, Wired/Wireless until reverting to previous firmware, running the Netgear Genie fix it client, then rebooting.
- Netduma-FraserFeb 07, 2019NetDuma PartnerSo it was a disconnect rather than not being able to toggle WiFi?
