LegionLord
Feb 07, 2019Follower
Wireless Networks will not enable
So yesterday all devices lost internet access. I checked and router has the most recent firmware. I check the boxes for "enable SSID broadcast" and apply. Even rebooted router. Can not see our wi...
Netduma-Fraser
Feb 07, 2019NetDuma Partner
Thanks for the workaround Blazey, when did the issue present itself to you?
Blazey
Feb 07, 2019Initiate
This happened to me on 2/5/19 at approximately 5pm EST. LAN/Wireless had worked in the afternoon on my home network, then stopped working between 4-6pm EST.
To be clear, the issue that affected me was with all devices at once, Wired/Wireless until reverting to previous firmware, running the Netgear Genie fix it client, then rebooting.
- Netduma-FraserFeb 07, 2019NetDuma PartnerSo it was a disconnect rather than not being able to toggle WiFi?
