Fabi1997
Aug 10, 2020Follower
With Fibre no connection Xr500
My Xr500 is connected to a media converter because it's not Fibre compatible. Converter is connected with the Wan port. Do I have to change something in the router settings? Because internet provider ...
Netduma-Fraser
Aug 10, 2020NetDuma Partner
You need to select the login option in Settings > Internet Setup, then apply and you should get the internet.
