Crowder
Jun 20, 2021Aspirant
WLAN devices cannot see LAN devices
Hello,
So I have a problem that I can't seem to solve. My WLAN devices cannot see my LAN stuff. Not only that but they connect with my public IP address. For example, I try to access my NAS through my laptop and it doesn't let me do that. I check on the logs and the laptop is trying to access from my public IP adress. Any idea what the hell is happening?
Thanks.
- john070102Aspirant
I am also having the same problem,if anybody can help please reply. I have mybkexperience that wlans are not discoverable to lan
- Netduma-FraserNetDuma PartnerCrowder do you have your laptop connected to your ISP modem WiFi by mistake as that shouldn't be possible. Regardless, it is an issue NG are aware of and unfortunately so far I haven't found a suitable workaround
- CrowderAspirant
No, my ISP router is in bridge mode with everything disabled, no Wifi, or anything else other that provide internet to the netgear router. The weird part is that it used to work fine, I don't know how long ago, I just discovered this issue while trying to watch some Plex content on my Chromecast.
If it's something that cannot be solved user-side... well, I'll have to contact Amazon.
Thanks!
