westk
Aug 01, 2024Aspirant
WMM & XR1000
Hello, I´m struggling lately with any kind of traffic from my cellphone (webcam traffic 5 Mbps - 10 Mbps) and this affects to the latency on my PC to the router. I was wondering to start testing with...
westk
Thanks for the rapid answer. I´ll try changing those on my phone.
Netduma-Fraser
Aug 01, 2024NetDuma Partner
How do you have the QoS page setup?
- westkAug 01, 2024Aspirant
Disabled, is not a Internet issue
- Netduma-FraserAug 01, 2024NetDuma PartnerIt can help with local traffic so I would suggest at least trying it to see if it helps
QOS enabled, same thing. The funny part that is the Router not even SEE the local traffic.
- FURRYe38Aug 01, 2024Guru - Experienced User
The latest one. The info is in the first post.
