westk
Aug 01, 2024Aspirant
WMM & XR1000
Hello, I´m struggling lately with any kind of traffic from my cellphone (webcam traffic 5 Mbps - 10 Mbps) and this affects to the latency on my PC to the router. I was wondering to start testing with...
Netduma-Fraser
Aug 01, 2024NetDuma Partner
QoS isn't a enabled/disabled type feature - how have you set it up exactly?
westk
In fact, I have Auto enable, always on and off..
- Netduma-FraserAug 01, 2024NetDuma PartnerWhat are the percentages you've set?
- westkAug 01, 2024Aspirant
70% of both
- Netduma-FraserAug 02, 2024NetDuma Partner70% is a good starting point but doesn't work for everyone, worth experimenting with it to see if you can get better results.
- westkAug 02, 2024Aspirant
I put the QoS in always active and 10%. Obviously doesn't work because is internal traffic. The router doesn´t even see it.
