westk
Aug 01, 2024Aspirant
WMM & XR1000
Hello, I´m struggling lately with any kind of traffic from my cellphone (webcam traffic 5 Mbps - 10 Mbps) and this affects to the latency on my PC to the router. I was wondering to start testing with...
westk
Oct 08, 2024Aspirant
Hello community, I got here looking for a weird issue that I never know what it was until I read someone here with the same issue. The thing is when I share my cellphone camera with my PC (both connected to WIFI6 Netgear XR1000) 20 Mbps, the PC starts to having a lot of latency with the router and with Internet too. I realize the last week because a reddit post, that could be the MU-MIMO feature that is enabled in router. I turned off and everything started working as it should. BUT, when past 1 day, it starts to "fail" again, and the feature in the router is turned off. What I have to do, is enable again and reset the router. That´s my workaround so far but I don't know how to fix it definitely.
Oct 08, 2024Guru - Experienced User
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
Lets try a full on factory reset and setup from scratch using a wired PC and web browser:
Afterwards, set MU-MIMO to enabled.
Set manual channels to 1 and 40.
Be sure that Smart Connect is enabled.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
