westk
Aug 01, 2024Aspirant
WMM & XR1000
Hello, I´m struggling lately with any kind of traffic from my cellphone (webcam traffic 5 Mbps - 10 Mbps) and this affects to the latency on my PC to the router. I was wondering to start testing with...
westk
Oct 08, 2024Aspirant
Hello community, I got here looking for a weird issue that I never know what it was until I read someone here with the same issue. The thing is when I share my cellphone camera with my PC (both connected to WIFI6 Netgear XR1000) 20 Mbps, the PC starts to having a lot of latency with the router and with Internet too. I realize the last week because a reddit post, that could be the MU-MIMO feature that is enabled in router. I turned off and everything started working as it should. BUT, when past 1 day, it starts to "fail" again, and the feature in the router is turned off. What I have to do, is enable again and reset the router. That´s my workaround so far but I don't know how to fix it definitely.
Netduma-Fraser
Oct 08, 2024NetDuma Partner
What is the phone you're using and how are you doing that exactly? Do you have smart connect enabled or disabled?
