westk
Aug 01, 2024Aspirant
WMM & XR1000
Hello, I´m struggling lately with any kind of traffic from my cellphone (webcam traffic 5 Mbps - 10 Mbps) and this affects to the latency on my PC to the router. I was wondering to start testing with...
Netduma-Fraser
Oct 08, 2024NetDuma Partner
What is the phone you're using and how are you doing that exactly? Do you have smart connect enabled or disabled?
westk
Oct 08, 2024Aspirant
Literally I put that info in the last message.. I do not use Smart Connect. This happen in both 2.4 & 5ghz.
- Netduma-FraserOct 08, 2024NetDuma Partner
I don't mean the connection method I mean via a third party app, phone manufacturer app etc.
- FURRYe38Oct 09, 2024Guru - Experienced User
So how about some feedback on the question presented. Need more details to better help you out.
