Noahh
Feb 24, 2020Guide
Works perfectly but can’t do it
So I recently tested what my ping would be like if I didn’t use a power line adapter so I had to move my pc across my house and I got double the download and upload speed and it fixed my ping and maki...
Netduma_Alex
Feb 24, 2020NetDuma Partner
Hmm... A mesh network might be worth looking into.
If your house is very large it can be an expensive option though, you'll need lots of units.
What kind of speeds are you getting at both ends of the Powerline adapter?
Make sure that both adapters are gigabit and all wires being used are gigabit.
Noahh
Feb 24, 2020Guide
The power line adapter is a tp link 1000 I think and the cables are cat6 but I’ve heard even with a mesh extender it is expensive and it might have more delay than what I have. For speeds I’m getting as low as 50 mgbs and as high as 80/90 but I’m supposed to be getting up to 300
