TAJ68PR's avatar
TAJ68PR
Tutor
Mar 21, 2019
Wouldn't connect to internet after reboot
I have an XR500 with firmware V2.3.2.40 I had to do a  reboot and when I did it stopped conecting to the internet. my isp is Frontier and it's an ethernet connection to the ONT. I tried spoofing the mac address of the Frontier router but that didn't work.  I had to connect the Frontier router, call Frontier have them resetup the Frontier router then I called them back and had them release the ip address on the Frontier router then I was able to connect the XR500 and it connected to the internet.. Is that normal will I have to call Frontier every time I reboot the XR500 or loose power? By the way I had to call Frontier and have them release the ip address on the Froniter router for the initial setup of the XR500.
  • No you shouldn't have to do that at all. I'd suggest setting a static IP on the frontier for the XR500 and it should re-establish a connection after a reboot.
    • TAJ68PR's avatar
      TAJ68PR
      Tutor
      I have the XR500 connected directly to the ONT via ethernet not using the Frontier router. Is you answer still the same?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        No doesn't apply, thanks for the info. This might have been a one time thing for new connection of the router.
