josephquake
Sep 21, 2021Tutor
wps does not work for me
I already tried it with the physical button and through the graphical interface and tried both ways with pin and push. try to give internet to a cell phone and a smart tv with no result
Netduma-Liam
Sep 22, 2021NetDuma Partner
Thanks for posting!
As this is a feature of Netgear's it may not be something I'm able to help with too much as member of the Netduma team.
There is a KB article that Netgear have detailing the exact steps you should follow, here's a link to that:
https://kb.netgear.com/24094/How-do-I-use-the-WPS-Wizard-on-my-Nighthawk-router
josephquake
Sep 22, 2021Tutor
it doesn't work i'm using the latest netgear xr300 firmware, could that be why it doesn't work?
- plemansSep 22, 2021Guru - Experienced User
does it work if you manually connect devices (just type in the password)?
- josephquakeSep 22, 2021Tutor
I already did the push method and pin method without result
- Netduma-FraserSep 22, 2021NetDuma PartnerCan you connect the devices using the wireless password?
- Netduma-FraserSep 22, 2021NetDuma PartnerAs above, can you connect using the password?
