WhatitDo
Aug 05, 2020Aspirant
WTF is wrong with Netgear customer service
case 431035997 Case Summary: XR500 - Router keeps droping Internet Product: XR500 The router keeps disconecting from my Modem, and when it does if i restart my router it works fine. I had to...
WhatitDo
Aug 06, 2020Aspirant
thank you for the information. i have done the roll back and factory reset more then once it has not fixed the issues. do you have an idea when the new patch will come out
Netduma-Fraser
Aug 06, 2020NetDuma Partner
So you tried using TFTP? There will likely be a new build in the beta next week - I couldn't say though when you'll get an invite. If I can I'll try and boost you up the list.
