Rjdelew
Jan 11, 2018Initiate
X10 vs XR500
I just bought an X10 router 2 weeks ago. Its still possible to return based on the stores Christmas policy. Should I return and get theXR500 or am I better off with the X10?
NandoFL
Jan 23, 2018Star
My son want to buy an XR500. We already have the X10. The X10 is an excellent router. The best I owned so far. It manage two Xbox and two PS4 and never have problem with the ports.
I don’t see any benefit with the XR500. Still, he will buy it. He will pay for the router. The question is, can this two routers co-exists with one cable modem only? Will I be able to set either router on bridge mode? What about QoS? Which one should be in charge?
Thank you in advance for your suggestion.
- Netduma-FraserJan 23, 2018NetDuma PartnerUnderstand your concern. The XR500 QoS is unlike any other router's QoS solution. It will enable everyone to use the internet at the same time without causing each other to lag/buffer. The gaming devices can be prioritised to ensure they have the very best connection, along with the Geo-Filter they truly optimise their game as much as is possible.
What I would suggest:
Modem > XR500 (wired devices) > X10 (AP Mode)- NandoFLJan 23, 2018Star
Thank you for replying to my message.
A couple of more questions...
Per your suggestion, I should connect both routers this way...
I suppose I should turn off QoS on the X10 and let the XR500 do all the QoS related job? Can I also turn off the wifi on XR500 and only use the wifi on the X10? (The X10 wifi is superb).
Again, thank you for your help and information.
- schumakuJan 23, 2018Guru - Experienced User
The idea behind the AP mode is to re-configure the X10 to become a Wireless Access Point only - so you can retain the WiFi functionality (and the network switch ports). Advanced - Advanced Setup - Router/AP/Bridge Mode. A little bit an expensive WiFi AP I must admit.
- PyretechJan 29, 2018Initiate“My son want to buy an XR500. We already have the X10. The X10 is an excellent router. The best I owned so far. It manage two Xbox and two PS4 and never have problem with the ports.
I don’t see any benefit with the XR500. Still, he will buy it. He will pay for the router. The question is, can this two routers co-exists with one cable modem only? Will I be able to set either router on bridge mode? What about QoS? Which one should be in charge?”
I have a similar set up 1 cable modem to a switch from the switch to two different routers. The caviat is I pay Comcast an extra $5 a month for a second IP address. This way each router has its own NAT.- NandoFLJan 30, 2018StarThat is a good idea. I would like that so my son can have his own router with a another ip address.
Unfortunately I called my cable company (Spectrum) and they don’t offer that service. They tried to sell me another cable subscription. I declined of course.
Thank you for the information.- WhatisjoseApr 05, 2018AspirantHey may I ask what speeds you're paying for and what speed youre getting from your router wirelessly? I have spectrum ultra 300 but only get around 230 with my nighthawk x6 so I might want to upgrade depending on your answer
