Rjdelew
Jan 11, 2018Initiate
X10 vs XR500
I just bought an X10 router 2 weeks ago. Its still possible to return based on the stores Christmas policy. Should I return and get theXR500 or am I better off with the X10?
NandoFL
Jan 23, 2018Star
Thank you for replying to my message.
A couple of more questions...
Per your suggestion, I should connect both routers this way...
Modem > XR500 (wired devices) > X10 (AP Mode)
I suppose I should turn off QoS on the X10 and let the XR500 do all the QoS related job? Can I also turn off the wifi on XR500 and only use the wifi on the X10? (The X10 wifi is superb).
Again, thank you for your help and information.
schumaku
Jan 23, 2018Guru - Experienced User
The idea behind the AP mode is to re-configure the X10 to become a Wireless Access Point only - so you can retain the WiFi functionality (and the network switch ports). Advanced - Advanced Setup - Router/AP/Bridge Mode. A little bit an expensive WiFi AP I must admit.
- NandoFLJan 23, 2018StarI agree. It is expensive. :)
I always believe that if it is not broken, don’t try to fix it.
But my son still want to buy xr500. Thank you for the information. It is appreciated it.
Have a good day.
