Rjdelew
Jan 11, 2018Initiate
X10 vs XR500
I just bought an X10 router 2 weeks ago. Its still possible to return based on the stores Christmas policy. Should I return and get theXR500 or am I better off with the X10?
Netduma-Fraser
Jan 28, 2018NetDuma Partner
You can use multiple yes, you wouldn't be able to Geo-Filter them all but should be no need. QoS can definitely help in this situation.
rebel_orbi
Jan 28, 2018Tutor
Are there any routers that offer 10GBe and don't cost an arm and a leg?
I have an X10 also and debating if I should keep it or return it.
Its my main router connected to a Synology using LAG and two R7000 APs.
My cost was around $220 USD for it.
My priority is strong 10GBe and Link Aggregation. WiFi coverage would be a bonus.
