sluggeracce
Jan 08, 2019Follower
Xbox - Traffic prioritization
The router successfully recognizes my xbox one regarding traffic prioritization. My quesiton is, does the function prioritize gaming input only? Does party chat and other datafeeds get the same treat...
Netduma-Fraser
Jan 08, 2019NetDuma Partner
It primarily does the actual game but if the party chat etc are in the same port range it will prioritize those as well. If you know the exact ports for gameplay you could do this manually but in reality the party chat etc will not use much bandwidth at all so you would likely not notice a difference at all.
