Lamontagne
Jun 07, 2018Aspirant
xbox and playstation disconnects
Hi I purchased the XR500 5 days ago. 1st 2 days was working great. Last 3 days I have had my xbox one X, xbox S and my PS4 Pro all were disconnected when I turned them on. They are all wired conne...
XRaptor29
Jun 07, 2018Luminary
Do they disconnect when being used or on standby / instant on?
Lamontagne
No they work great when being used. It was working fine yesterday when I went to play last night with instant on. It 1st happened 2 days ago. I did the whole reset everything. Worked fine after reset. Turned them on last night and worked great. Went to turn it on today to download something and was disconnected. Tried my other Xbox same then tried ps4 same. I also just tried my computer that is hard wired as well and it’s disconnected too. So everything I have hard wired is disconnected and everything wireless works great.
- XRaptor29Jun 07, 2018LuminaryI think it's a firmware side issue. They probably have a setting set to high. When the consoles are on standby they're pulling less than 100mbps and after a few hours the router probably drops it thinking the device is off. I've seen multiple people talk about it in the forum. The thing that fixed it for now was turning the consoles into power save mode. Hopefully Netgear can fix the issue since the Xbox One X isn't the only one being affected.
- LamontagneJun 07, 2018AspirantOk I’ll try that. Thanks for the help
- Netduma-FraserJun 08, 2018NetDuma PartnerHi Lamontagne, I've sent you a PM with a firmware that may fix the issue.
