darkangelpt
Jun 24, 2018Aspirant
xbox one double nat
Greetings everyone, this is my first post. i have the netgear xr500. the way i have it set up is. isp router rj45 to xr500. then connected to pc xbox one and ps4. recently i stardet using my xbox ag...
Netduma_Jack
Jun 25, 2018NetDuma Partner
Hi Dark Angel - the easiest thing to do here, if you would prefer to not put your RJ45 into bridge mode, is to put the XR500 in a DMZ on your RJ45. Can you find this in your modem settings?
As an aside, it is odd you are losing speeds on your RJ45 in bridge mode but I don't know much about that model so won't be able to help you there I'm afraid!
Finally, double NAT is not terrible, but it can make connecting to other players, such as your friends, harder. So it's best to resolve it.
- darkangelptJun 25, 2018Aspirantmy bandwith is 200 /20.and in bridge mode it gets 100/10 because my isp router sucks in bridge mode. they cant help me with that.
using ap mode Solves that problem, but i lose all the things i needed for the router. in my ps4 i think its fine(i think)
im a begginer in this routers thing.
i can put my xbox in static ip than dmz. but wich ip should i use? everything my pc the netgear xr500 all are dinamic ip. im confused what to do- Netduma_JackJun 25, 2018NetDuma Partner
You want to put your XR500 into a DMZ on your modem. Not your other devices, just your XR500 router.
If you go onto the RJ45, does it have a DMZ option? If yes, you need to put the IP address of the XR500 into it.
Does that make sense?
