darkangelpt
Jun 24, 2018Aspirant
xbox one double nat
Greetings everyone, this is my first post. i have the netgear xr500. the way i have it set up is. isp router rj45 to xr500. then connected to pc xbox one and ps4. recently i stardet using my xbox ag...
darkangelpt
Jun 25, 2018Aspirant
my bandwith is 200 /20.and in bridge mode it gets 100/10 because my isp router sucks in bridge mode. they cant help me with that.
using ap mode Solves that problem, but i lose all the things i needed for the router. in my ps4 i think its fine(i think)
im a begginer in this routers thing.
i can put my xbox in static ip than dmz. but wich ip should i use? everything my pc the netgear xr500 all are dinamic ip. im confused what to do
Netduma_Jack
Jun 25, 2018NetDuma Partner
You want to put your XR500 into a DMZ on your modem. Not your other devices, just your XR500 router.
If you go onto the RJ45, does it have a DMZ option? If yes, you need to put the IP address of the XR500 into it.
Does that make sense?
