darkangelpt
Jun 24, 2018Aspirant
xbox one double nat
Greetings everyone, this is my first post. i have the netgear xr500. the way i have it set up is. isp router rj45 to xr500. then connected to pc xbox one and ps4. recently i stardet using my xbox ag...
Jun 25, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. .
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the XR router gets from the modem.
- darkangelptJun 25, 2018Aspirantgonna try that. put in my isp. modem dmz the ip for the xr500.
