darkangelpt
Jun 24, 2018Aspirant
xbox one double nat
Greetings everyone, this is my first post. i have the netgear xr500. the way i have it set up is. isp router rj45 to xr500. then connected to pc xbox one and ps4. recently i stardet using my xbox ag...
Jun 25, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. .
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the XR router gets from the modem.
darkangelpt
Jun 25, 2018Aspirant
gonna try that. put in my isp. modem dmz the ip for the xr500.
