Blue_Cheese
Aug 19, 2018Initiate
Xbox One settings to improve lag/performance
Hello,
New to this community! Just wondering if there is a good setup for xbox one (specifically playing Destiny 2) to reduce lag and improve performance of the router. Currently have comcast w...
Blue_Cheese
Aug 21, 2018Initiate
Thanks for the reply! I will do more research but most likely will upgrade it to XR500.
Aug 21, 2018Guru - Experienced User
Can get into a XR450 for $100 less if you have a costco near by and a member. :smileywink:
