BUG_812
Dec 19, 2022Initiate
Xbox one stopped connecting to netgear nighthawk XR1000
My son's Xbox One has stopped connecting to my wireless router - Netgear Nighthawk XR1000. It was connected for a few days after I set it up, then it just stopped. Not sure if it was because I blocke...
- Dec 19, 2022
Thank you everyone for your suggestions. I ended up getting through to Netgear support and yes, I had already tried most of the suggested solutions. We ended up having to do a factory reset. I will never be using the app to block a device again!! So far it all seems to be running ok and the xbox is connected once again.
Netduma-Fraser
Dec 19, 2022NetDuma Partner
What does it say on the console when you attempt a connection? If the Access Control hasn't properly disabled and there is no way to disable it again then you can try re-enabling the block and disabling the block, otherwise it's likely you'll need to do a factory reset. Then if you want to block it again do it on the Device Manager or use Traffic Controller instead.
