jsh2291
Oct 29, 2018Aspirant
Xbox One X & XR500 Wired Disconnects
Before I begin, I've seen a number of posts with a similar issue claiming to be resolved by a firmware update, but having updated the firmware to the latest available, I can confirm this issue has no...
Netduma-Fraser
Oct 29, 2018NetDuma Partner
I've sent you a PM with the latest beta firmware with an additional fix for those still experiencing the issue.
Chaosphynx
Nov 08, 2018Aspirant
I am also experiencing this, I turned off “instant on” (which is undesireable) on the Xbox one x...which worked for a day. Still facing this issue as well. I have updated to the most current firmware as well. Does the beta firmware fix it? If so, I’d like to receive it as well.
