jsh2291
Oct 29, 2018Aspirant
Xbox One X & XR500 Wired Disconnects
Before I begin, I've seen a number of posts with a similar issue claiming to be resolved by a firmware update, but having updated the firmware to the latest available, I can confirm this issue has no...
jsh2291
Nov 09, 2018Aspirant
I've already done that - I've had the assigned IP address on both the non-beta and beta router firmware
Nov 09, 2018Guru - Experienced User
Whats the IP address pool size? Default? If so, try 192.168.1.100 to 200.
Might try going back to first version of FW and see if the problem is still present...
