jsh2291
Oct 29, 2018Aspirant
Xbox One X & XR500 Wired Disconnects
Before I begin, I've seen a number of posts with a similar issue claiming to be resolved by a firmware update, but having updated the firmware to the latest available, I can confirm this issue has no...
mfontillas
Mar 03, 2019Aspirant
I have purchased an XR500 a a couple of months ago and I have been experiencing the same issues reported on this thread. I am on the latest firmware update and have tried assigning a static IP to my Xbox One X. This connectivity drop through wired connection seems to still be an isseue as of 03/03/19. Is there a fix for this beside bouncing the router?
Mar 03, 2019Guru - Experienced User
Whats the IP address pool size? Default? If so, try 192.168.1.100 to 200.
Is Instant On enabled on the xbox. Disable it if it is.
Set up a RESERVED IP address ON the router for the xbox. Set Automatic IP addressing on the xbox.
