jsh2291
Oct 29, 2018Aspirant
Xbox One X & XR500 Wired Disconnects
Before I begin, I've seen a number of posts with a similar issue claiming to be resolved by a firmware update, but having updated the firmware to the latest available, I can confirm this issue has no...
mfontillas
Mar 03, 2019Aspirant
I have purchased an XR500 a a couple of months ago and I have been experiencing the same issues reported on this thread. I am on the latest firmware update and have tried assigning a static IP to my Xbox One X. This connectivity drop through wired connection seems to still be an isseue as of 03/03/19. Is there a fix for this beside bouncing the router?
Netduma_Jack
Mar 05, 2019NetDuma Partner
Could you also check your firmware version? Does it end in .40? Click the 'i' icon in the top right corner to find the version. If it's not .40, please upgrade to it: http://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.2.40.zip
- mfontillasMar 05, 2019Aspirant
Yes my unit is on the latest firmware. XR500 V2.3.2.40
- FURRYe38Mar 05, 2019Guru - Experienced User
Whats the IP address pool size? Default? If so, try 192.168.1.100 to 200.
Is Instant On enabled on the xbox. Disable it if it is.
Set up a RESERVED IP address ON the router for the xbox. Set Automatic IP addressing on the xbox.
- Netduma-FraserMar 05, 2019NetDuma PartnerHave you changed your Xbox to energy saving mode rather than instant on mode? As instant on mode has been one of the causes of the issue
