jsh2291
Oct 29, 2018Aspirant
Xbox One X & XR500 Wired Disconnects
Before I begin, I've seen a number of posts with a similar issue claiming to be resolved by a firmware update, but having updated the firmware to the latest available, I can confirm this issue has no...
Netduma_Jack
Mar 05, 2019NetDuma Partner
Could you also check your firmware version? Does it end in .40? Click the 'i' icon in the top right corner to find the version. If it's not .40, please upgrade to it: http://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.2.40.zip
mfontillas
Mar 05, 2019Aspirant
Yes my unit is on the latest firmware. XR500 V2.3.2.40
- FURRYe38Mar 05, 2019Guru - Experienced User
Whats the IP address pool size? Default? If so, try 192.168.1.100 to 200.
Is Instant On enabled on the xbox. Disable it if it is.
Set up a RESERVED IP address ON the router for the xbox. Set Automatic IP addressing on the xbox.
- Netduma-FraserMar 05, 2019NetDuma PartnerHave you changed your Xbox to energy saving mode rather than instant on mode? As instant on mode has been one of the causes of the issue
- mfontillasMar 07, 2019AspirantThank you, i have made this change a couple days ago and so far i have not had any issues. Do you know if there is some type of update in the works. The instant on feature is really great to have enabled. With this feature off i will have to do all my console, accessories, games, and app updates manually. Hoepfully this gets fixed because these items were not cheap and is would be sad to not use them at their full capabilities. Thanks again
