mebaby333
Jan 16, 2019Tutor
Xbox One X NAT Type Unavailable
Good Day!,
I am having an issue where the NAT Type on my Xbox One X will go to Unavailable "Could not connect to the Toledo Servers". When i turned off the Geo Filter and wait about 2 minutes, the...
Netduma-Fraser
Jan 16, 2019NetDuma Partner
Is it preventing you joining any games? If not all you need to do is add your friends to your allow list in order to chat with them. Do you see anything blocked on the Geo-Filter when you don't get a teredo IP address?
mebaby333
Jan 16, 2019Tutor
I do not see a block but i see a icon pop up on the map when it is searching for NAT, which looks like a dedicated server... When i turn the geo filter off, it takes about 2 minutes and the NAT type goes to open, and then i can turn back on the filtering.
- Netduma-FraserJan 16, 2019NetDuma PartnerIs that dedicated server icon being allowed or blocked? It should just be a misreading caused by the Geo-Filter and adding your friends to the allow list would allow you to connect to them
- FURRYe38Jan 16, 2019Guru - Experienced User
What FW is currently loaded?
