Link8900
Mar 31, 2019Tutor
Xbox One X upload issues
Hello,
I have posted on the Xbox forums about this but I still cannot resolve this issue and wondering if anyone has advice.
All of a sudden over the past few days my upload speed JUST on my ...
Mar 31, 2019Guru - Experienced User
Is the xbox wire connected?
If other devices are are working well and it's just the xbox, then possibly the xbox is the problem.
Besure to disable Instant ON on the xbox. This is known to cause problems.
- Link8900Mar 31, 2019Tutor
Thank you for the reply.
I use the ARIS Sb8200. I've done some research and it seems like multiple people are having the same issue just with Xbox. I even directly connected the xbox to the modem with the same poor upload results. I guess I will have to see what Xbox has to say.
- FURRYe38Mar 31, 2019Guru - Experienced User
Ya, if you directly connected it to the mode and seeing same issue, thats a console issue.
Good luck.
- ZirkawnMar 31, 2019Aspirant
I have literally the exact same setup as you, and I get the same poor upload results. It has to be an xbox issue because when I play on ps4 my upload speeds are what I paid for. I also have the same provider as you.
- FURRYe38Apr 01, 2019Guru - Experienced User
I would contact MS support about this and let them know.
Let us know if you find out any information from MS.
