Link8900
Mar 31, 2019Tutor
Xbox One X upload issues
Hello,
I have posted on the Xbox forums about this but I still cannot resolve this issue and wondering if anyone has advice.
All of a sudden over the past few days my upload speed JUST on my ...
Link8900
Mar 31, 2019Tutor
Thank you for the reply.
I use the ARIS Sb8200. I've done some research and it seems like multiple people are having the same issue just with Xbox. I even directly connected the xbox to the modem with the same poor upload results. I guess I will have to see what Xbox has to say.
Mar 31, 2019Guru - Experienced User
Ya, if you directly connected it to the mode and seeing same issue, thats a console issue.
Good luck.
