Junior86
Jan 12, 2022Tutor
Xbox Series X not showing in Device manager
Hey team I got a XR1000 with a AX6000 WiFi Range Extender connected. I haven't enabled Fastlane on the extender and I've updated both to the latest firmware and factory reset both after. M...
Netduma-Fraser
Jan 12, 2022NetDuma Partner
What is the IP of the XR1000 - it should be 10.0.0.1 or 192.168.1.1 and what is the IP of the Xbox you're getting? Do you keep the Xbox in an instant on/standby state at all?
Junior86
Jan 12, 2022Tutor
Xbox IP is 192.168.1.15 and yes it's on standby. Should it be on energy save?
- Netduma-FraserJan 12, 2022NetDuma PartnerBest to shut it down completely and then turn on and it should appear on the device manager
