Junior86
Jan 12, 2022Tutor
Xbox Series X not showing in Device manager
Hey team I got a XR1000 with a AX6000 WiFi Range Extender connected. I haven't enabled Fastlane on the extender and I've updated both to the latest firmware and factory reset both after. M...
Junior86
Jan 12, 2022Tutor
Xbox IP is 192.168.1.15 and yes it's on standby. Should it be on energy save?
Netduma-Fraser
Jan 12, 2022NetDuma Partner
Best to shut it down completely and then turn on and it should appear on the device manager
- Junior86Jan 12, 2022Tutor
Tried restarting the router, extender and the xbox
- FURRYe38Jan 12, 2022Guru - Experienced User
If you turn OFF the Extender, does the xbox appear on the XR then?
- Junior86Jan 14, 2022Tutor
It showed again after factory resetting the router and extender. I think it disappeared after testing the Fastlane option on the extender. Could there be a bug here?
