Junior86
Jan 12, 2022Tutor
Xbox Series X not showing in Device manager
Hey team I got a XR1000 with a AX6000 WiFi Range Extender connected. I haven't enabled Fastlane on the extender and I've updated both to the latest firmware and factory reset both after. M...
Junior86
Jan 12, 2022Tutor
Tried restarting the router, extender and the xbox
Jan 12, 2022Guru - Experienced User
If you turn OFF the Extender, does the xbox appear on the XR then?
- Junior86Jan 14, 2022Tutor
It showed again after factory resetting the router and extender. I think it disappeared after testing the Fastlane option on the extender. Could there be a bug here?
- Netduma-FraserJan 14, 2022NetDuma PartnerThe XR is handling the IPs for the devices and so can interact with them directly, sounds like the fastlane option bypassed this which is good - if you didn't want to use the Geo-Filter/QoS etc
- Junior86Jan 15, 2022TutorIt’s a shame when I went back to basic it stopped recognising my Xbox for some reason. All good now
