92jthomas
Sep 14, 2020Guide
Xbox Speeds slow.. Help!
I have tried researching so long on this and I really don't want to pay this 60 bucks to talk to the netgear support. But I have this XR500, it has been absolutely amazing in every way. I just bought ...
Netduma-Fraser
Sep 17, 2020NetDuma Partner
Try this, add your console to Traffic Prioritization with a manual rule:
Source 1 - 65535
Destination 1 - 65535
TCP/UDP
This will prioritize your console completely, this is not a good idea usually but if you do that then it will give you a good idea of what speed it is possible to get.
Source 1 - 65535
TCP/UDP
92jthomas
Sep 17, 2020Guide
Okay, I will try that tonight. Thank you! I feel so dumb considering I got this router and I am having to learn this way to get it set up correctly. I used to build pc's and program too. Thanks again!
